It's a custom backing plate, attached to a 1800rpm motor. The base is a drop from a bearing block for a rolls rock crusher, with custom feet. The mid section is 3" pipe and the motor mount and table section is all custom. I know it sounds stupid saying "custom" to every other part, but, they are one-off custom parts.Logan76 wrote: how did you make the sander may I ask?
For fabrication, this is a sweet setup. The backing plate is the main part, the rest you could come up with on your own if you really wanted to build one.Logan76 wrote:I use a fixed belt sander alot, they are great for cleaning up parts, and deburring etc, I was just thinking if it was easy enough I would make my own.
