shop help
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
runaway3087
Car: 1996 nissan s14 with rb20 swap
hey im new to this but anyway i have a rb20 that was from NC. the turbo is going out and is leaking oil. I want to put the 25 turbo on it but do i have to do anything else to it if i do this? I live in south dakota and was wondering if anyone knows where i can take it to get it worked on. maybe around denver, minneapoils, or chicago.
mychalous
Car: '96 240SX "Silvi"
Go to the 240SX section and ask. I don't have much info on the topic but you might want to search first. Definitely don't want you getting flamed.
tyndago
Chicago - Try AMS - the Evo guys. Ivan there has a bit of experience with the KA, and a ton of Supra experience.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
the 25 turbo will bolt up to the 20 motor without ne mods, they both share the same ext manifold, all the water n oil lines are the same, good upgrade to the rb20 man! keep us updated!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
The only issue you are going to run into is the boost soruce for the wastegate actuator.
The 20 turbo has a nipple off the compressor housing with a hose that goes to the actuator.
The 25 turbo doesn't have that nipple so you may need to have a fitting made to fit one or your IC pipes for a boost source for the actuator.
Return to “GTR Forum / Skyline Forum”
