drifts14x wrote:Hey there guys, I'm posting out of frustration, my KA-T swap could not be going worse right now. So far, I have disconnected the stock manifold, but I cannot work it past the steering column (and I can't break the bolts loose to take it apart). As for my nice fuel injectors, 4 out of the 8 screws will not come out, as they won't move, and the heads are stripping. The only good thing I've managed to get working right is that I drained the oil, and took off the pan. This sucks, what do I do.
I know exactly how you feel. I had both problems.
For injectors: Use plenty of wd-40, and some vice grips. I tried to use a screwdriver, and I ended up destroying the heads of the screws. The vice grips are the answer.
For the exhaust: I had a lot of trouble too. I ended up biting the curb and breaking those manifold-downpipe bolts loose(or breaking the bolts). Just use a really big breaker bar and wd-40. It took me about a full day to take off my whole exhaust. Half of that time was spent cutting that egr pipe. I'm surprised you didn't seem to have trouble with it.
Good luck.
