offtheline »
https://forums.nicoclub.com/offtheline-u5954.html
Fri Jul 11, 2003 5:40 am
I guess it is hard to say. Did you do the install yourself? If not, you should take it back to the shop and ask them to look at it. A shop should have reused the spring silencers from your stock setup. If you did it yourself, you may want to go ahead and redo it with the spring silencers. I would doubt that the install is bad because it really isnt a difficult process. The other thing you might want to check is that all of the nuts are tightened correctly.
