DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Dec 17, 2002 5:56 pm
The Tokicos will break in and soften up over time. Q45tech makes it clear they're not breaking in, but wearing out. The new rubber will do a lot to ease the ride while the shocks soften. If your other components are original, you probably need to replace the sway bar end link bushings if you have a sway bar, and check the rear strut bushings and the tension rods too. Each rubber component is like a spring that is in series with the rest of your suspension, and each one hardens as it ages. Do the struts first, and then start replacing bushings if the ride is too harsh or if they're cracked/torn.
