Shocking Fuel Injectors?
RisinTiger
Car: 1993 Nissan 300zx Convertible ~ Pearl White
2000 Toyota Corolla ~ Super White
Has anyone done this before with a? One of my cylinder is not working. The ohms read at 7.7OHMS. How would i shock it to jump start the fuel injector again? Does anyone have any good idea to making it work again?
http://www.twinturbo.net/nissan/300zx/f ... ctors.html
i've also heard of a pulse starter
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Never tried it, but at most, it's a band aid. The broken thing needs to be replaced.
I can't for the life of me understand why so many people are trying to cheap out on these cars lately. It's going to cause more headaches down the road.
You have a 93 N/A. You have old style injectors. The injectors have been exposed to ethanol for a long time now. The ethanol has broken down the disc that controls the duty cycle. The injector is dying. End of story. Replace it.
nissanfreak12
Car: 92 300zx 2+2 TT
RisinTiger wrote:Has anyone done this before with a? One of my cylinder is not working. The ohms read at 7.7OHMS. How would i shock it to jump start the fuel injector again? Does anyone have any good idea to making it work again?
Exactly what Ace said, and "shocking" the injector will not work, period. Also, don't buy just one, do the job once and replace all of them. Get the newer style injectors, they can handle ethanol better since that is not going away. A little more expensive, but trust me, completely worth it. If you go on TT.net, a guy name Bernie has the newer style injectors in the rail with pigtails for a very reasonable price.
RisinTiger
Would I need any mod for the newer style injectors? i'm sitting on squares injectors right now. also would a 94-96 lower plenum work with the new style injector on top of my plenum?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
You would need to get the adapter kit for new style injectors. It's basically just the connectors themselves that you solder in, plus some adapters that you drop into the fuel rail itself so that the new injectors sit properly. It's totally worth it though. I actually bought my adapter kit from Z1 and then bought stock remanufactured injectors(sonic cleaned and flow tested) off ebay for ~$125 and they've been working great. I'm not recommending it or anything but if you're short on cash or something it's better than a bandaid.
