EW »
https://forums.nicoclub.com/ew-u28959.html
Sat Aug 20, 2011 2:59 pm
I have a proximity sensor on each of my three cars. One advantage of the Viper 5901 is that you can use the second sensor input for the prox and from the remote, on the fly, turn off the warning zone (chirps) or the entire prox sensor. We use the Bitwriter to tell the alarm what sensor is on that input and then any warnings or triggers to the remote will show "proximity". When installed and adjusted properly, they work great with minimal false warning or trigger.
From my 20+ yrs experience:
1. Install prox sensor in the center of the headliner in front of domelight if there is one.
2. Read the directions!
3. Set the field sizes outside away from buildings or other cars. The mass affects the fields. Florescent lights will affect the field.
4. Set the sensor with the windows how you plan to leave the car. If you are going to leave the windows down most of the time, set the sensor that way. If you leave the windows up, set the fields with the windows up. If you have tint, the warning zone will probably have to be turned way up to pass through the film. If set like this, the outer field will be way outside the windows when the windows are left down. Set the inner zone to 10-12" inside the vehicle. Set the outer zone so that if you put your face right on the front door windows, the warning zone is triggered.
5. If you have tint, and have the sensor turned up, it will go out of the windshield. I use a foil type sunshade 24/7 to help "corral" the prox field from going out the windshield.
6. If you install a prox sensor in the console, any metal like change or soda cans placed above/around it will heat up and cause falsing. Also the steering wheel and metal seat frames will affect the field. That is why you put it in the headliner.
Drive through.
