maxnix wrote:Are they a two piece design? Seperate hub to adjust offset?
How much do they weigh? Load rating?
Interesting to see how that offset will work.
they are a 2-piece wheel. Offset was fully customizable, as as the backpad size. I choose the 15/0mm offsets and the O-Disc Backpads.
Im not sure of weight or load ratings.
The offset's should be just fine, the Y33 Q can swallow alot of wheel up. I'll use the wheels i just sold as a example. these were 19x9 +24mm Low Disc Front and 19x10.5 +5mm Super Low Disc Rear. Granted the car sits about 2" higher than I want it to (which is why these wont go on until it drops more) But I lost a little size in the rear, but gained offset, I drew both sets of wheels out in illustrator with the sizes and offsets and the rears sit the same distance out from the hubs as the old wheels. The fronts poke about 10mm further out than the old wheels (the the SSR's, old wheels were sucked in about 1")
