sijoko wrote:Looks good so far. Can you separate the Infiniti logo? Might make things easier.
What kind of tool are you using?
-sijoko
I don't know if I can seperate the logo from the plenum. It looks like it is cast right into it . Has anybody tried to remove it before?
I am using an Electrical Rotary Tool with a 120 Grit Sanding Wheel. It's set on the lowest speed, which is a claimed 12000 rpm. To buff it, I will probably use a 200~500 Grit wheel, and then go buy, or make, a buffing wheel.
It should look really "pimp" when it's done.
But, I still have to do the TB. Theat is going to be a real pain. That are so many nooks and crannies . Very difficult to work with.
I wonder, what would happen if I sand Blasted it? Would that make it shiny too? Or would that just leave it pitted?
