Well, definitely don't want to do the solid lifters or you're in for a treat. What's your oil pressure at idle? What is your oil pressure on a cold engine under mid to heavy throttle? Identify which lifters are making the noise and go from there. If they are all making noise, then you definitely have oiling issues. If the noises are intermittent, I would go to a heavier oil. Mine makes noise every blue moon, but they shut up and I just keep on keeping on .float_6969 wrote:I've used 15w-15 and it still ticks and the pressure is still low when the oil warms up. When the oil is cold, it never ticks.
When you rev it up and the pressure increases, the ticking stops. It's just the idle oil pressure it too low to keep them pumped up.
The pump was new when the motor was rebuilt about 20K miles ago, but the motor has had low oil pressure since the rebuild. I know I told the engine builder that I was going to run boost and N20, and so we decided to build the motor "loose" but I was under the impression that was the in regards to the rings. I suppose he could have run the main and rod bearings on the loose side too, which would explain the low oil pressure. If it's from loose mains, shimming the pump won't help, will it?
What about that check valve in the head that is supposed to be for the lifters? Anybody heard of that failing or getting something stuck in it?
Maybe I just need to go to solid lifters, LOL!
Good luck with the shimming, but I don't think it's the problem, champ. My idle pressure on my 240 bounces around as well between 25 and sometimes at or around 5psi (per my digital gauge and electric sender). Like I said before, the lifters will make some noise and will actually affect the exhaust note as well. I know the thing has oil in it and I know the pump is good, so I just let it idle and it ultimately shuts and I'm happy for a while. I know the noise is annoying though, because sometimes it'so loud, you think something is wrong with the engine or it's out of oil. I've found that fresh oil changes helps as well. And you're using a much thinner oil than I am, so I would go for a thicker grade oil before pulling apart the pump. Where is your idle RPM per your in car tach-vs-your sds hand controller?float_6969 wrote:Yea, I tried lucas.
I'm gonna try shimming the pump and see what happens.
Any guess as to how much I should shim it?
I am still going to shim it and I was thinking about the Amsoil 15w-50 too (my father in law is a dealer). IDK if 1200 RPMS is enough, but I haven't tried a 50 viscosity oil either.ks13 wrote:I would still try shimming the pump, but if you dont feel like doing that and want to give something else a shot - use a 20w-50 or 15w-50 racing oil (i use amsoil) and set your idle RPM to about 1200 rpm. If you did use clevites and your oil pressure is indeed accurate at idle, you want to stay away from thin oils and opt for heavier viscosity instead. You have a few options here before you do it all over again.
1200 hasn't been enough, but I do have the idle set to about 1000, so I could bump it up. I might have to with these HKS 264's, IDK how they'll effect idle.boost_boy wrote:How does the car act if you hold the idle at 1200rpm, 1100rpm, and 1000rpm? The point I'm trying to make is, if you have your idle set below 1000rpm trying to respect the factory suggestions, you may want to idle it higher if it helps the oil pressure.
Dee
