shimmed j30 assembly failure, emergency help!
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
i cannot for the life of me get the long output shaft in, the small shaft goes in just fine. it is hitting the inner teeth like its not aligned right. any tricks? i need my car back on the road asap.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
i had to tap mine in with a hammer.
compactfean
daily
Ive beyond tapped it! Lol
compactfean
daily
So do you have to align the passenger side teeth with the output. Shaft teeth before you tightening the vlsd and ring gear? Before shimming this rear end I could force one side to move without the other and now I can't. Since I can't move the shafts separate if it wasn't aligned when. I tightened it, could that cause this?
moso
90 240sx ka24de RIP
man thats hard to follow first thing in the morning. long story short when i tightened mine i had the foresight to do so with the stub axle in the carrier.
compactfean
daily
So I think I see what your saying. So take the assy. Back out, loosen, align with output shafts, tighten and reinstall?
moso
90 240sx ka24de RIP
yea, i put the stub axle in the carrier before tightening the ring gear just to make sure everything lined up. its ballz tight in there with that extra shim, too tight to turn. i still had to smack the long stub axle in with a hammer, i wasn't very nice to it either if i remember correctly. just to note i put the j30 vlsd center section into my stock open pumpkin with the stock ring and pinion to keep my speedo correct, if it makes a difference.
compactfean
daily
Woo! I told that b**** who's boss! I loosened up the ring gear/vlsd and main caps, beat the hell out of it to align it and beet it in and it went. Thanks man. I definitely was not nice to it! Lol. Now I just gotta tighten her back up. Im excited to get rid of my welded and 2 piece driveshaft...and 4.08 gears. So for anyone shimming there vlsd align the passenger side output shaft with the guts before you tighten the ring gear! Man, the next one I do will be so much easier.
