Thoughtful_One »
https://forums.nicoclub.com/thoughtful-one-u29843.html
Wed Dec 24, 2008 9:30 am
After doing some work on my car, I decided to try out the shimmed method temporarily.
I could really get one M10 washer in there since I didn't think there was enough thread to hold the wastegate on.
Took it for a spin, and boost climbed to around ~9 from about 6.5 PSI stock. On and off-throttle response is only a little better.
I did a WOT pull 1-4 th gear last night, and I was really surprised how quick it was. 1st was all wheelspin, 2nd was wheelspin past 5K, third and fourth to redline was pretty damn quick.
For some reaosn, my boost was just climbing though, leveling out at around 11 PSI.
You guys need to understand that a US swapped SR will be slow to respond without a boost controller or the factory soledoind wired in. Nissan added the wastegate solenoid for a reason, and running the wastegate directly to the hotpipe will never be as responsive as something to actuate the wastegate electronically.
