Shiftknob Replacement?
J30Guy612
Car: 1993 Infiniti J30
Hey guys does anyone if you can replace the shift knob on the J30, without taking apart a ton of stuff?
Thanks alot, mine is a bit faded, and if I can find a nice one I'd like to swap it out.
Defiant
Car: 1997 J30
Use a couple of small screwdrivers or the like on the sides of the pushbutton to release the plastic. Then, a 14mm(?) nut under that.
xxcrashxx
Car: 95 Infiniti J30
u gotta use a deep well socket to get the nut out tho. im not too sure of the size of the nut, due to the fact that i used a pair of needle nose plyers to get mine out. i went for more of a "manual" look. got one of those shifting knobs off ebay, that look like one from a manual, and i also got a leather boot for the gear shifter too. :D
J30Guy612
The push button on the top of the shift knob?
xxcrashxx
yep, the part that you push down. its best to get one of those little flathead screw drivers that look like a toothpick, but dont bend as easy. and put that on the left and right sides to unclip the thing button from the sidewalls of the handle.
or get a larger flathead screwdriver and go from either the back or the front of the button and pry it from underneath. hope that helps ya out. good luck.
J30Guy612
Thanks alot, I appreciate the info!
