benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Tue Sep 21, 2004 8:54 pm
If you're not just imagining things and you really do have to "match revs" to get it to shift, then it sounds very much like your clutch is not fully disengaging. Although, if that's the case, it seems odd that you only have trouble going from 1st to 2nd. Do you ever have trouble getting it from neutral to 1st? Check to make sure you're clutch fluid reservoir isn't low. It's about the size of an eight year-old's fist and is under the hood in the extreme left rear corner (driver's side)
