Z-owned wrote:I would try changing the transmission fluid to some redline mt90 if your sure it's not your clutch.
REDWINTERZ wrote:My first maintenance post since the reconfiguration... I almost posted this in general discussion
Ok so here's the deal. My car is, and has been, having trouble shifting gears. Particularly in the 1st -2nd and 2nd - 1st transitions. However, there is an all over feeling of hard, then snappy shifting. Sometimes I can even hear it when it finally decides to budge (metal on metal thud).
Do I have a synchro problem, or do I need to add some sort of gear lube? Ideas?
Only thing I can say is try getting a hold of nissan trans fluid, I have found out the hard way that usually the manufacturers trans fluid is best. Redline is also a good option and since your trans seems to be badly worn you may need some friction modifiers (such as those found in some Redline fluids). either of these should be good, I wouldn't just run Mobil1 Synth in it or some other high grade oil, run something that may help fix the problem.
