shifting problem
93Z
Car: 1993 300zx 2+2
my Z is getting hard to shift into 1st and reverse. Ive replaced all the hydraulic lines and parts a few months ago so theyre fine. the shifting has been getting much harder lately. i cant tell if its the synchronizers going out or my clutch. but my clutch doesnt slip when im driving. anybody know any ways to tell
NolimitZ32
Your clutch would be doing the opposite of slipping if it was the cause of your hard shifting problem. If your clutch doesnt disengage all the way it could be causeing your problem. When wa the last time you changed the trans fluid?
Nismovs
Car: '92 F150 Flareside 4x4 302 5spd
'11 Honda CRZ 6spd
'90 Dal-Tech Racing IMSA 300zx Turbo SM-Z
Another thought is your selector forks. I don't remember for sure, but I believe 1st and reverse along with another gear are on the same fork.
93Z
Car: 1993 300zx 2+2
I changed the fluid about a year ago. I might switch to redline and see if it helps
93Z
Car: 1993 300zx 2+2
I looked up at my clutch master cylinder and I still have another half inch or so of threads. You I should just adjust it a little more?
93Z
Car: 1993 300zx 2+2
How do I know when its adjusted perfect ? I got it shifting alot better but I feel like its a little off
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Free Fish
And a move to technical :D
