flames5351 »
https://forums.nicoclub.com/flames5351-u29913.html
Fri Mar 23, 2007 6:17 am
Ok first off... I have searched and I have read and tried many things.
Heres my problem. It is hard to shift gears, its like trying to shift into a brick wall sometimes. I recently just put a new clutch in it in the fall. F1 racing off ebay.. * I know cheap **** and I shouldn't have done it*. A couple months later it started to get hard to shift and it just got progressively worse. I change clutch master, and slave, removed damper. Bleed everything correctly no air. Adjusted the clutch pedal. Still can't shift. Sometimes when I was in gear the car would move forward with the clutch pedal down as if it was an automatic *clutch was grabbing slightly somehow*.
Now a little background info... when I did the clutch change I put mobil 1 synthetic in it... which I later found to be GL5 and I read that eats synchros *so i'm totally kicking myself in the ****.
My question is... Do you think my synchros are bad? Do you think possibly its the ****ty ebay clutches pressure plate? Or should I try adjusting the pedal some more?
I just don't want to buy a new clutch and transmission when thats not the problem *but i'm pretty sure thats what needs to happen*... BTW I will be going exedy.
Thanks a lot everyone... And I already know i'm a retard for putting the GL5 and messing up my baby
no flaming I did hours of searching
