Not much to write here...transmission is eitehr on the way out (llikely) or possibelk slow shifting due to restricted flow= low line pressures.
Solution:compelte transmission flush.Sometimes this is not enought to clean things out you may wanna bypass factory heat exchanger in radiator with a cooler ($50 part easy DIY).Not so much to prtotect transmission, as chances are most major heat induced damage has already occured but to make sure flow thru heat exchanger is not restricted.
If you shift imrpove after the above you saved your transmission, if they dont then there is litle that can be done ( at least there is no slippage)
Fred..
