slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Fri Oct 28, 2005 9:10 pm
Mine is too when it is cold(ie it has sat overnight). I run MT90 too, and it certainly smoothed things out. However if I try to baby it in the mornings shifting slowly, I get grindage. So I just shift it as quick as I can, with a little uumph and it goes right in. <shrug> Go figure.
Can you give us some more details on what's happening? Are you grinding on shift, does it not attempt to go in gear at all, what? If you can't say for sure when the last time the M/T fluid was changed, that would be a wise starting point. Whatever you do, just don't use GL5 fluid, GL4 only. Also the clutch master/fluid could partially be to blame: makes sure the clutch clevice pin is adjusted on your pedal and the fluid is full/bleed. As the fluid is warmed(and expands), it could be allowing for further disengagement of the clutch disc.
Just some thoughts.
