rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Tue Apr 01, 2008 2:22 am
After you shift make sure your not keeping your foot on the clutch.... I've seen my girlfriend do this, my friends brother, and i did it too when i was a new driver in the 89' shadow!!.... you may not realize that you are riding the sh*t out of the clutch. if your having trouble going into 2nd, try shifting a bit faster at a higher RPM until you get used to the clutch a little better. As for slow launch, let the clutch out super effing slow until you feel the car start to roll then push it back in, do this a few times until you get the sweet spot figured out. Once you got it then just ad some pedal from that point..... as you go out with the clutch go in with the pedal, but ease it a little... you'll get it. That clutch is freaking stiff too, not the best to learn on but at the same time, it is the best to learn on, cuz regular standards are easier. Also push it all the way to the floor when you shift until you get used to it. Maybe move your seat closer to the pedals..... Have fun, and don't give up on the manual, its so much better....
