Shifting in the G35
rearweeldrivsmokinurface
Car: 2007 Infiniti G35 Coupe 6MT
Is it bad to shift gears not using the clutch in the G35...I was told its better to shift with out the clutch on Bikes and quads but not sure if its the same for cars...
ugaexploder
Car: 2007 Lakeshore Slate G35S
if you do it properly without grinding gears then it shouldn't matter, but most can't do it without grinding gears. it's really only used in drag racing anyways, i don't think it really gives you an advantage. i'd use the clutch just in case, but maybe if you're out having fun power shifting, then don't use it.
Thanx kid, yea im not using it to drag race or nothing and i dont grind any gears till it gets to 5th so i do it sometimes till 5th ger then i use the clutch lol..but thanx...
