shifter wobble, clutch pedal not working
zMikeyz
Car: z32/z31
i just bought a 90 z32, just wanted more opinions on what could be the problem before i buy a clutch kit, i thought maybe i need to change and bleed the clutch master and slave cylinders. But idk, help me out here please. Thanx :ohno:
es.biggs
Car: 1990 300ZX 5sp NA
Is there any fluid in your master cylinder? If not you could try filling it and pressing the clutch (or having a friend do it) and watch for leakage at the slave, master, or possibly along a line.
If you don't find leaks you could try bleeding at both bleed points (slave cylinder and under the hood, front passenger side on the fender) If that doesn't do anything we can go from there...lots of people on here know more about clutches than I do :)
The wobbly shifter could be worn shifter bushings. They are cheap but from what I hear they are kind of a PITA to change.
zMikeyz
Car: z32/z31
yeah there are fluids in the master reservoir, no leaks at all. would bad shifter bushings cause poor or no shifting?
Milton'Z Nissan'Z
Car: 1990 300ZX tt
1990 240SX
zMikeyz wrote:i just bought a 90 z32, just wanted more opinions on what could be the problem before i buy a clutch kit, i thought maybe i need to change and bleed the clutch master and slave cylinders. But idk, help me out here please. Thanx :ohno:
Is the clutch reservoir full? If not fill it up and bleed the slave and see if the pedal starts to feel like it should. If it's empty there is a reason for it, most likely the slave seal is shot. If it is, it will leak out pretty quickly. If it's full and the pedal feels like nothing, it could be the master. The slave goes the most often.
The shifter bushings are pretty easy to change. About an hour from the top, or 10 seconds from the bottom if you are pulling the trans to do the clutch.
zMikeyz
Car: z32/z31
ok so the problem with the clutch was the slave, so i replaced it. Now i just need to try and see if that fixes shifting, cuz i was not able to shift into any gears with the car on..... ill try it tomorrow. now what if it doesnt shift even after the clutch system has been bled? only thing left would be the clutch right?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
did you get allt he air out of the system? you bleed it at the slave and at the fender?
zMikeyz
Car: z32/z31
so i tried it, clutch pedal engages but the shifter wont even engage into any gears still.... so im guessing its the clutch????
zMikeyz
Car: z32/z31
sorry yes i did take all the air out, fender and slave.
evildky
06 Nissan 350Z GT
pedal adjustment, at rest there should be no pressure on the clevis, if the clevis is too far in or too far out you loose range of motion
