Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Wed Aug 25, 2004 1:52 pm
If you mean that when you pull up on the shifter it comes out of the transmission, you are missing a retaining clip. If you mean that when you drive, a slight pull on the shifter will cause it to pop out of gear, that means the shift collars and dogs in your transmission are excessivly worn.
