OK I think I solved my picture posting problems:
created by picasa2html.com
I am trying to work through the steps in the FSM. I think I flunk step 3 because I get 0 volts between position 7 on the harness and the metal plate surrounding the OBD II connector with the ignition switch on. So I go to step 4, fuse is good, ignition switch seems OK (it starts the car etc.). I think all the other substeps in this step are covered by the fact that my stop lights still light when I hit the brakes so I move on to Step 5. I do get continuity between pin 6 and OBD port metal so on to Step 6. Now I am supposed to find and disconnect the harness for the park position switch. Is it behind the white plastic piece in the pic? Have I done anything wrong here?
I have to head out for a Halloween party soon, so I am going to leave this here and see if someone replies before I can start working on this again tomorrow morning.
