astron »
https://forums.nicoclub.com/astron-u3396.html
Mon Dec 08, 2003 12:43 pm
Okay, I did what i thought was the proper shifter repair on my s14 5sp, pulled the shifter and replaced a little white piece on the very end of the shifter. Nada, as bad if not worse than it was before. Did i get the wrong part? What's the deal?also, i redid my rear brakes, brembo rotors, axxis pads, new shims....I figured out the major problem with the old brakes though...the inside right rear pad was gone down to the backing material, the rest were in good shape, i replaced them all around 15k ago..Why would 1 pad wear out when the rest were decent? Sticking caliper? (It was on the piston side of the caliper...) or what? thanksast
