I am a new guy here, so bear with me. I was on my way back to work, and came to like the last intersection, and was heel-toe downshifting, geting ready to make the turn, and had some trouble getting into second. it was like it was hitting the synchro, grinding like a missed gear. I pulled it back out of gear and put it back in again, but had to stop hard because the light changed. when i got stopped, i could smell clutch burning, which is normal now that it has begun to slip a little, but when the light changed, it was stiff going back into first. i thought i wasn't gonna be able to get it back in gear. well, i got it in gear, but when i went to second, it was just as stiff, like something was binding the shifter. Third and 4th are fine, but that 1st and 2nd are just really stiff. What would cause this?
Thanks
:help
I checked it again an hour later and everything seemed ok. it was a little stiff, but still great in the rest of the gears, including reverse
I went back out a couple more after that and everything felt almost perfect. I moved it around the pattern a few times, and it then no longer would allow me to get into 1st or 2nd, whether it is running or not. will still go into 3-4-5-R. Any thoughts?
