Go on a diet.2kul wrote:Also my rear end shakes a lot. Thanks
What am I lookin for in those parts?Chingon wrote:check subframe bushings...check driveshaft, check driveshaft coupling, check rear axles.
New tires can be defective. You need to learn how to look for belt seperation or lumps. Ever plug them?2kul wrote:i have almost new tires w/ about ~85% thread left.
Youre problem sounds like a bad u-joint on the drive shaft. like its binding up man check it because you dont want the drive shaft letting loose on the road somewheresilviasxy wrote:I have the exact same problem, but mine shakes real bad in 1st gear around 5-15mph. I'm pretty sure it is the transmission itself because if it was the driveshaft it would shake all the time. I have also changed the transmission mount and it did nothing. There's a bearing in the transmission that is probably worn out.
