SHifter question
locoluna825
Car: 90 240sx coupe
Hey this ones for you guys that have taken your stock shifter out of your transmission. I just recently took mine off the entire assembly and its all together nothing missing.
I am concerned about this funny movement in the shifter, if you hold the bottom plate and tug on the top of the shifter where the nob goes. it has like some play in it, like it will move straight up until its cought by the clip. i didn't really notice it when it was on the transmission but is this normal? have any of you seen the same thing on yours? it just seems strange...
OMSIN
Car: 1993 240sx Coupe SE
if I'm not mistaken that play should go away when you hook it back up to the transmission.
mac_daddy
Car: 92 slicktop n/a
do u have both the snap rings back in?when i took mine out there was a snap ring that held down another snap ring.
locoluna825
Car: 90 240sx coupe
two snap rings? in side the body of the sifter assembly? if that's the case i can see that being the problem, i see another groove just below the first one and looks like something went there, but nothing there.
you are talking about the snap rings in the shifter and not the ones that hold the little rubber boot on arent you?
Warped161
Car: 90 s13 the never ending project
Why not get a short shifter and be done with it? Your shifter is about 18 years old, it's gonna be worn out a little.
locoluna825
Car: 90 240sx coupe
just got threw rebuilding the shifter assembly all new stuffs on it. besides im not really sure if the transmission is good anymore so im not ready to put a short shifter on till i know everything is in good working order. I do plan on saving up for a B&M short or a nismo sold shifter.
locoluna825
Car: 90 240sx coupe
sweet sohc intake mani i do want....
Warped161
^^^^Thanks. I have a B&M, if you get one make sure it's a second generation one. the first gen shifters vibrate like all hell.
locoluna825
Car: 90 240sx coupe
(BUMB)
Modified by locoluna825 at 9:49 AM 5/16/2009
locoluna825
Car: 90 240sx coupe
*bumb* is the thing below the first snap ring just a washer?
Modified by locoluna825 at 8:32 AM 5/18/2009
91white_ka
Car: s13 hatch
Yea I've heard about the double snap rings but only saw one transmission (s14) that had it. I would check to make sure your snap ring is all the way down in the groove.
locoluna825
Car: 90 240sx coupe
its definitely in the groove, very hard to get out of the groove without the tool. just below the Grove is another groove not nearly as deep but a definite groove. I called the dealer today and asked one of the guys if there was more than one snap ring or washer or spring below the first one and he couldnt seem to find one anything so im still kinda lost.
locoluna825
Car: 90 240sx coupe
bumb
mac_daddy
o sorry for no response i sold my 240 so i rarely get on here anymore. but yes there is one in the groove and that one holds the other snap ring in place. i just popped mine out with a screwdriver when i replaced my shifter
