shifter question
CadetLD
Car: 1991 Nissan 240sx Coupe
I searched....
The other day, while trying to merge with traffic, my shifter came completly off and went all wobbley untill it found its way back into place. If I lift up on the shifter it comes completly out. On top of that, my shift knob has seased completly and will not come off making it super hard to squeese those giant jesus-clips into place with the whole shift boot assembley flopping around.
So that being said. Does anybody know if SR Shifters are the same as CA shifters? Seems that SRs are alot cheaper and easier to find. What brand do you recomend and why? Thanks in advance fellas. -Shane
James@CI
Car: 89 Nissan 240sx with SR20DET
Yes the KA sifter will work in the sr tany and if you have AIM contact me screen name sr20detswaps
themadscientist
mine does that all the time. I could fix it but I like the drama.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
shift knob is locked on because nissan loves the lock tight.
idk on the shifter issue
themadscientist
spin it you *****!
float_6969
Vice Grips FTW!
CadetLD
Yall have no idea how stuck this knob is. Its NOT coming off lol. I had the whole shifter out of the car, in my bench-vise with a belt-type wrench. tried PB blaster,WD40.... The only other thing i can think of is heating the knob with a torch to mabey make it expand a little. But The good news is I finaly got that giant jesus-clip in and my shifter no longer pops out at random. Catch is the sticker that says where the gears are located is upside down lol. I guess Ill save up for an SR B&M shifter or something and modify the housing if I have to.
ca18detgabby
03 Infiniti G35
my bf used a belt wrench and it too him and his brother(neither of which are small boys) a good 45 mins to get it to come off.
float_6969
Heat > loc-tight
Heat up the metal part of the shifter. The heat will go up into the threads of the shift knob and should break the loc-tight loose.
themadscientist
it's sad when a guy can't get his knob off.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
A dremel and an inch diameter cutoff wheel. It is the handiest tool ever. It destroys what you are cutting off. but has saved me on several occasions.
themadscientist
home circumcision?
CadetLD
Okay, so do the stock CA shifters look identical to the nismo? God I hope not, because mine looks identical to the Nismo im looking at online. Pink markings and all.
themadscientist
pink markings? WTF? picture please.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
OK, FYI, all S13 shifters are exactly the same. You can use a SR, KA, CA shifter or any combo there of. Also, the R31, R32, R33 and Z31 shifters are also 100% identical to the S13 and S14 shifters. S15 is different cause it was 6 speed.
In summary: S13, S14, R31, R32, R33 and Z31 shifters are all the same, no matter what motor you have.
ca18detgabby
03 Infiniti G35
themadscientist wrote:it's sad when a guy can't get his knob off.
its ok it was my knob............ does that make it any better?
float_6969
This thread is NOT headed in a good direction...
CadetLD
The one in my car looks exactly like this.
https://www.rhdjapan.com/image...3.jpg
No pics of the one in my car, I finaly got those clips in and Im not takin it back out unless I absolutly have to or I get a short shifter lol.
themadscientist
Noooooooooooooooo! Say it ain't so!
