shifter problem!
platinum240sx
what up boyz whenever i start my car or really give it gas the shifter shakes like the whole ****ing short shifter and everythig is this normal and if not then does any body know what the problem is?
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Your transmission mount may have given out. To check, crawl under your car (preferably on jackstands) and see if u can lift your transmission near the driveshaft. If it seperates from the mount, the mount is toast. Fairly easy to replace.
platinum240sx
how much will it cost for a new mount?
JNM240
http://www.carparts.com sells one from Beck/Arnley for $62.50 for the S13. Im sure you would be able to pick one up (or at least order one) from your local auto supply store.
