leesredgt »
https://forums.nicoclub.com/leesredgt-u72829.html
Fri Mar 06, 2009 11:21 am
I put the shifter in a couple days ago and got all the locking rings etc... back on so it wouldnt pull back out.After i put it in i went through the gears to make sure everything was ok.
It goes through all the gears but theres alot of play in each gear.I dont know if its b/c theres is no transmission fluid in it b/c i just swapped it but i dont remeber it being this loose when i swapped it the first time.
So my question is:Is there a problem or is this normal untill you put fluid in or is somthing wrong?The car was fine before i pulled the engine from my hatch.
Thanks in advance guys.
