flanker wrote:Is it a 2 position switch (On/Off)? It seems spring-loaded but doesn't "lock" into a down position. Press it down, it comes back "up" when you remove your finger. Wondering if this might be faulty as well.
That's normal operation.... sounds like it's working fine.
Did the tips on your bulbs look melted, or possibly the tips in the connectors look charred? If so that's your culprit. You might also check for CHMSL (Third brake light) for charred connections there too.
If not, it may be the brake lamp switch, although mine just failed (forewarned by a "pop" in the radio when I pressed the brake pedal sometimes). If you have a dead short that's taking out a fuse that quickly, you should be able to narrow it down to one bulb assembly by getting several fuses and unplugging one at a time until your fuse doesn't blow.
Heath
