turtl631 wrote:Assuming you're driving relatively fast, i.e. 50 mph, approaching a tight turn in 4th gear so you push in the clutch and let off the gas and start braking down to say 20 mph...should i keep the shifter in the neutral position until i'm going relatively slow, or can i put it in 2nd or even 1st while still going 50 but WITH THE CLUTCH PUSHED IN? Reason I ask is mostly that i had to teach myself to drive stick, so some things still elude me, and also if i try to downshift before the speed and rpms match, its really hard to put the shifter in gear, as if im pushing the shifter past a spring loaded door or something. Whatever, I'm an idiot, someone please reply and help me out. Thanks!Ross
Keep the shifter in the gear you are downshifting to... for 20 mph you'd want to be in 2nd.
The proper way to downshift before a corner is as follows:
Before corner entry (3rd ---> 2nd):- Swing the top of your foot onto brake pedal- Depress brake pedal until car begins to slow- Push in clutch- Rotate foot on brake pedal while maintaining pressure, and blip the throttle with the heel of your foot. - Downshift immediately after blipping throttle- Release clutch- Rotate foot to brake pedal solely
AKA Heel-Toe downshifting
It should be very smooth and it will take some practice. Sometimes you can't rotate your foot so you'll have to learn how to use one foot to modulate both the throttle and brake pedal.
Make sure you practice without traffic or a fast stop... you will more than likely not get it right the first couple times you do it.
