Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon May 31, 2004 9:20 am
well, i was preparing to remove the shifter plate (bearing retainer plate, whatever). That's why I was asking. I pulled the bolts, and I couldn't get the plate to break loose, so I put it all back together to try another day. Plus I deduced from the lack of a transmission boot, that the gear oil i was leaking was coming from there, and not from the plate gasket. the spring itself isn't under a bolt, it's in a seperate housing between the bolts. Oh well.
