USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Thu Apr 24, 2003 7:33 am
I had the exact same problem in my coupe until last week. It had so much slop in it, that you could literally put it in 3rd gear and then move it over to where 5th should be... it was horrible.
Here is what you need to do to correct it. -Unscrew the shift knob-Remove Trim cover and boot-unscrew the upper dust boot-Remove the lowerd dust boot. You may have to cut a slit in it to get it up over the shifter.-Get a set of Snap Ring Pliars. Usually about 10 bucks from autozone.-Remove the inner C-Clip from the housing and then pull the whole shifter lever out of the transmission.
Look at the very bottom of the shifter. There is a ball like pivot at the end of it that is about 1/2 inch in diameter. This is the part that goes into the shift linkage and allows you to shift gears. Like this.
/ / <---- Threads / | | | | | | ( ) ( ) <--- Pivot Point | 0 <--- End of Shifter Rod
At the end of that, there should be a white plastic collar that will rotate around then end of the ball like so....
\_(__)_/
This is the peice that is wore out. Just go to your Dealer and order this peice, reinstall and it should be fixed. What happend on mine was that bearing was so wore out that is had become disconnected from the shifter as just just sitting in the transmission. On my last trip to the junkyard I got a new shifter rod with that busing already on it, pulled out my old one, fished out the busted bearing, reinstalled..... shifted like it was brand new, no more slop.
I hope this helps you out, my drawings are kind of crude, so if I find pictures, I will post them to clear it up a bit.
Joe
