rinny wrote:I have an 03 G35 Sedan and here is my issue. When I put the car in reverse a fuse blows.
That's never good...what fuse?
There is only one thing that will blow a fuse a short to ground. If reverse (and the lights) are suspect the entire circuit will require inspection. The most common cause for this tends to be body repair at some point in the cars life span.
