Shift Selection Bulb Size
Althomas49
Does anyone know the Shift Selection Bulb size in the center console for a 2013 Pathfinder? I have not been able to find it on any diagrams and the dealer couldn't tell me either? I know the factory bulb has an orange coating on it that I doubt I will be able to find on a replacement, but with the bulb size, maybe I can opt for an colored LED bulb instead.
302LVR
Car: 02' Pathfinder SE, 89' Mustang LX 5.0
Check out Sylvania.com and their vehicle bulb replacement guide. They usually specify factory bulb sizes. I dont have a 2013 but have a 2002 and if the shifter area is big enough, a 194 or 168 bulb is a very popular size on most bulb sockets. That's what mine uses and i know for a fact since i replaced the original halogen with an LED bulb. Hope that helps
302LVR
Althomas49
I don't actually see that bulb listed though? Is it being called another name??
302LVR
Althomas49 wrote:I don't actually see that bulb listed though? Is it being called another name??
Yes, i noticed that as well. You're probably gonna have to remove the one thats in there n go from there. I'm gonna bet its either a 194 0r 168(same) size bulb since its a very popular size but you'll be certain when u pull it out.
joewmorrissey
Here is the one I just used to replace the shift selector bulb:
https://www.superbrightleds.com/moreinf ... r/199/873/
