dsm007 »
https://forums.nicoclub.com/dsm007-u28569.html
Sat Aug 20, 2005 11:31 am
do ya have a new short shifter in it?If thats the case then ya prob need to break in the nylon bushing for a little while,then again it might be worn syncros which needs a transmission rebuild to fix,could also be the gear oil your using too,ya running 75-90 weight in it?Ya could should bleed a little more too and see what happens......I was thinking maybe syncros because you say 4th and 5th are easy to select into,I remember in my DSM I had a worn second gear syncro but after I drove for a few blocks and got her lubed up she was just fine........So go ahead and bleed it some more,drive around for a bit and let us know how it goes so far.
