benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Sun Jul 09, 2006 5:11 pm
I'm not familiar with the s14 auto transmission, but I think most modern auto trannys have various triggers that can cause this. The idea is to keep you from driving until you fix whatever problem it is detecting. I'm not sure if the s14 does this or not, but if it does then the following should at least get you to work:
You should be able to put it in neutral before turning the key. Then just start the engine, put it in drive and go. You'll probably have to repeat that if you should happen to put it in park at any given time.
Again, I don't know enough about auto s14s to be of much help in fixing it.
