Ceara »
https://forums.nicoclub.com/ceara-u190217.html
Thu Aug 20, 2015 9:35 am
I have a 2006 Infiniti M35X
Put the car into park one day and heard a big CLACK. Then the shifter went loose and wouldn't engage in any gear.
There is no Infiniti dealer nearby so I had it towed to the local Nissan dealer. The part that is needed is a shift lever, underneath the actual shifter. (At least that is the name I was given. I am not even sure that is the proper part name.) Some rod with a fork shape on one end and some clips. That is the only name I know. I would appreciate any proper terminology or links to diagrams if those are available. The transmission itself is OK according to the Nissan dealer and all I need is that little part under the shifter.
Well, in true Infiniti parts, the part is backordered from Japan and no one knows when it will, if at all, arrive.
Is there any other work around for this part? How many other years/models would this same part be used for? Or an off market piece, whilst waiting for the OEM?
My only other option is to call all the junkyards I can all over Canada and the USA if needed. I am located in Canada.
I would appreciate any information.
Thank you!
