GEO wrote:Shift higher? WHat?///// A troque converter always you to launch at a higher RPM
That is correct. Well, I was thinking it would also allow you to shift to the next gear at a higher rpm than auto's normally do because of the way they worked.
Please correct me again if I'm wrong:
the hstc's gears or whatnot are made so that they don't lock until a higher rpm (i.e. 2600+ rpm) or something. Of course, this will allow you to build up rpm while staying put so you can launch at a higher rpm.
Does this not also affect when gears 2,3,4 come into at the rpm spectrum?
If not, I'm sorry for the misinformation, that's why there's always more qualified members to correct my mistakes .
For sure tho, they are suppose to also provide more responsive shifts
From levelten.com support:Quote »Dear Enthusiast,We do offer 2 upgrades for applications such as yours and they are a pts hydrosystem upgrade and a pts torque converter upgrade. They will get rid of all the lag and the hesitation off the start and shave off anywhere from 1/2-1 second off 1/4 mile times. Now pts hydrosystem upgrade will get rid of the factory lazy luxury shifts and replace them with throttle oriented shifts. They make transmission much more responsive to power upgrades and transmission then can with stand the punishment of forced induction or power adders (i.e. nitrous).[/quote]yelnatsch517:You can either get a generic one (i.e. Haynes or something), or get one off another car. There are install instructions somewhere on this board, just search for "transmission oil cooler"
