Shift indicator light in console
t_b0ne3
Car: 2002 Infinti QX4 4wd My first Nissan was a 1985 720 4wd P/U. My other ride is a 2005 FXDWGI
I did a search and couldn't find anything on this but was wondering if anyone knows if the console "buttons" for the gears are supposed to light up or not? If they are supposed to be backlit what bulb do I need and how do I access it to replace the one that doesn't work now?Thanx!
KyooX4
Car: 2001 Infiniti QX4 4wd
I don't think they're supposed to light up. At least, my don't.I think that's what the gear indicator in the dash is for.
t_b0ne3
Ok I just thought they looked like they should be lit up but I've had mine for almost three years and they never did work! LOL
Pwnin O'Brien
What "buttons" are you talking about?
t_b0ne3
The lexan looking ones beside the shifter in the console they are colored down inside the brushed aluminium center for the shifter?
Pwnin O'Brien
You mean the indicators next to the shifter? I'm about 90% they should be backlit when your headlamps are on, but I could be wrong.
You mean the P-R-N-D-2-1 in the following picture, right?
EDIT: After looking at the FSM, it shows that the letters P-R-N-D-2-1 should be backlit when you have the parking lamps or headlamps on.
Modified by Pwnin O'Brien at 1:24 AM 1/9/2010
t_b0ne3
Yepper tho
Pwnin O’Brien wrote:You mean the indicators next to the shifter? I'm about 90% they should be backlit when your headlamps are on, but I could be wrong.
Yepper those are the ones! If they don't light I was thinking they would look pretty sweet with a super bright white led behind them,but like I said they never did light since I got the car?
Pwnin O'Brien
Well it should definitely be lit. The bulb that goes in there is a 194 I believe (don't quote me on that). That bulb is probably the single most difficult bulb to replace in the vehicle since you have to partially dismantle the center console and the shifter trim to change it. Most likely it burnt out with the previous owner and it was just too much of a hassle to replace.
t_b0ne3
Pwnin did the FSM have a bulb listed for that?
Pwnin O'Brien
t_b0ne3 wrote:Pwnin did the FSM have a bulb listed for that?
The FSM doesn't list the bulb, but when I replaced my bulb I'm pretty sure it was the same bulb that goes in the center high-mounted stop light (which is 194 if I recall correctly).
t_b0ne3
That just smells like somethings gonna get busted during the bulb change! LOL Thanks for the help I'll have to see what I can find as far as a tear down to get at the recpticle and what I can get in an hid look l.e.d. for it.
t_b0ne3
The third brake light does take 194's so if that's what you used I just need to find out what I can get away with space wise a three l.e.d. one sigle 194,Thanx again Pwnin!!
Empty V
1982 Chevy Corvette C3 Shark
It's not as hard as it looks. The console just pops out and the only part that is removed is the stuff covered in wood grain, the shifter and brushed aluminum stuff stays in place along with the covered dual cup holder.
Get a 168/194 lamp but make sure it doesn't exceed the 194 size, anything bigger will not fit. The same goes for the High Mount Stop Light/3rd Brake Light. This one worked for me WLED-xHP5
Open the oversized cup holder and just lift up. After it's dislodged rotate it 90* so the shift knob fits through it. The lamp is located in the rear driver's side of the shifter console and is at a weird angle. It took me a little while to find and takes some force to twist it out. Remember LED's are polarized and and if it doesn't light up twist it 180*.
Billy
t_b0ne3
I like it! That's just the look I was hoping to get there and glad I'm not gonna break all kinds of overly expensive plastic! LOL Thanks again V! You da man!
t_b0ne3
Just an update on this and the other thread,with the console out already all you have to do is grasp the rear of the shift panel. (the brushed aluminium) and wiggle up and down gently and it will dislodge alowing you to lift and move forward and down to have full access to the bulb at the rear drivers side of the panel. When you replace the shifter panel,make sure to put the front end down in first there are two tangs that must be placed in first then just press down on the middle rear until it seats in and doesn't move.
Modified by t_b0ne3 at 8:16 PM 1/14/2010
Zeus2008
Car: 2000 Nissan Pathfinder
I have a 2000 Nissan Pathfinder
My Centre Console light (automatic Transmission shift light) has gone out
I took the console apart, but could not remove the whole thing because the 4x4 shifter is part of the console and the leather covering on the 4x4 shifter is attached to both the console and the 4x4 shifter.
From what I could see under the console where the automatic shifter is, I could not locate the console light.
Could someone tell me where the light is located? Pictures or a diagram would be very helpful, as well as instructions on how to get to it, since I cannot remove the whole console because of the 4x4 shifter.
Thank you in advance.
P.S. I have seen YouTube videos of other Nissan vehicles, Sentra, Altima, Frontier, Titan...but none of these provide any clues to where I can find the light on my vehicle.
atraudes
Car: 2001.5 Infiniti QX4 4WD
I think this is it
No specific tips on getting to it since mine isn't a similar year, but I imagine you're able to feel under that side and get to it like that. It should be a twist and pull to extract the socket.
Zeus2008
ahhhh thank you so much. I will take a look at it again tomorrow. Much appreciated.
