droll »
https://forums.nicoclub.com/droll-u7639.html
Thu May 27, 2004 10:09 am
When it was hooked up in the car were you able to move it with the clutch pedal? If it is jammed, you'd have to remove the clutch and pressure plate and take a look. Its not part of the transmission so you wouldn't have to replace that. Its part of the clutch system, located inside the bell housing.
You may have a bad bearing, which is jamming it. Or the pressure plate is what's jammed, but I would think you'd have some play if it were the pressure plate. You probably won't know until you take a look inside. Since you have the trans out of the car already, the rest is easy.
