Tru180Kid »
https://forums.nicoclub.com/tru180kid-u135451.html
Sat Nov 28, 2009 2:28 am
So originally i bought a CA that was in bad shape, long story short i ended up taking her to MA-Motorsports in Baltimore and had them buy another block and test it out and now she runs like a champ.
the mods i have done were Walboro 255, Sr20 Turbo Elbow and Downpipe, Ebay Tial Knock off BOV.
a few minor things i been meaning to get worked out
1. First off i running a stock Turbo setup and the gauge is reading 10psi, i havent touched the boost nor do i have a controller to adjust this. Is my gauge not reading corectly or is there another issue that was cause it to run at 10psi? Its not really a problem but if its the gauge then iw ould like to replace it.
2. The car is running very rich...not to the point of bogging down but the smell of gas is fairly heavy and the gas mileage is pretty s***ty, i get to about maybe 230 before i have to fill up. MA told me my knock sensor was bad so they eliminated it...after reading up im thinki9ng this could be the issue.
3. When driving around if i hit boost and dis-engage the clutch to let the engine rpms go down to idle, the rpms drop way below idle level to almost 200-300rpms and tehn returns to idle which is 800-1100 and some times the car cuts off because it dropped to low. Im todl my BOV spring is messed up which is causing the BOV to stay open and casue this problem.
I just recently picked up a SAFCII 444cc Injectors and an SR20 Turbo for my next mods
Any input would be appreciated with fixing these issues.
