Where exactly are you saying to connect this ground? From Metal frame of MAF to a known ground or cut the existing ground wire and replace it with a new one or ??????240sxmech wrote:....and if you havent ran an external ground from your maf sensor than you need to, the ground in the wire-harness is not good after time and can cause a loss in ground resulting in your problem......
Try checking the plugs. A loose plug(s) can make a BIG differenceS3t0_S13 wrote:i havent checked my plugs in a whilethere was oil on 2 of them, one a decent amount, one not soo much
i didnt know that could factor inyes the car does smell like gas, i will take a look right nowas i have my fender off rewiring my ECU harness thats been eaten away by my driver side wheel
Sucks that you're having so many issues with this Seto. Keep at and GL, but you might ought to just plunk down the dough to have a professional diagnose this for you, or do a swap.redtop91 wrote:When you are ready to swap that lump of iron out for a real engine, I'll be here to help out.
this is to u smurf13 i was reading your symptoms and if i where u i would definitly check your timing chain rattle a little closer that could be your hole problem. i dont no what engine u have but i have a ka24e and they are know for timing chain problems mine personaly wore out the guides, tensioner, as well as chain and sproketssmurf13 wrote:my car is doin the same ish...for the first month or so it was doing fine then all of a sudden...bam!!! no power. from 20% throttle all the way to WOT it feels just the same. sumtimes if i ride second to around 4500 then stomp on it, it will feel like it pulls, its especially dreadfull from a stop. im gunna check my fuel pump and distributor rotor today. A local mechanic thinks its a timing issue. he said the chain could be marked improperly but so far here is everything ive changed and has had no affect.
here's a list of everything we checked that i can rememberits got good if not perfect compressionits got good fuel pressurechanged oil filterchecked timing, its at 20 advancechanged spark plugs and wireschanged coil packchanged o2 sensorchanged fuel injectorschecked tps and mafchecked coolant temp sensor. all seem to be working right.
and i also have mad timing chain rattle, im not sure if that has anything to do with it
