S3t0_S13 wrote:my problem is throttle it seemsmy car has no dfference on like 20% throttle and WOTi can punch it in 1st gear or give it half pedal and it still picks up the sameit comes and goes though thats what has me this morning my car was running perfect till about an hour ago where it just dipped on the power band and i felt like i was 1 gear above what i should be...........
Highly doubtful. The throttle is controlled by a cable attached to the gas pedal. If it were to not open fully, you would feel resistance to movement in the gas pedal.
Just reading through this thread, I'd start with the error code. While it is indicating there may be an injector leak, consider that the OBD codes are based on certain conditions that exist that cause the ECU to believe there is a leak. Depending on how it is programmed to sense this, it could be reading fuel pressure, or O2 sensor readings in relation to injector duty cycles. If any are out of range, it might assume there is a leak, but ultimately other related failures can cause the code to be triggered. You should probably invest in a FSM as it will probably have a troubleshooting flow chart that will take you step by step through the process of diagnosing the cause of the code.
If resolving the code doesn't resolve the problem, the FSM will probably have a flow chart for a problem that closely resembles the one you are experiencing.
Worst case scenario, you might consider taking it to a machanic or the dealer. A shop will typically charge you for the diagnostic, but allow you to put that towards the repair if you decide to have them complete the repair. I had a short in the wiring on the S13 I owned and didn't have the time to troubleshoot the issue. In total I spent about $300 for them to find and repair the short. In the S14 I owned, I had a coolant temp senspor wire break within the insulation causing intermittent problems. I had a company car at that time so I was able to take my time with it and repair it myself. Total cost to me was a wire connector and some electrical tape. It took me a couple of weeks to figure it out though as I could only look at it after work and on the weekends.
