sheared stud/bolt in turine exhaust housing.
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
the bolt was sheared when i got the turbo, and i have tried to use an easy-out to get it with no luck (my drill just hangs and starts to smoke)
any suggestions on how to get it out, or should i just take it to a machine shop and have them drill it out and re-tap it for a slightly larger stud/bolt?
thanks
-terry
oversteer180
Car: 1990 Silver 240sx
this wasnt on the sr turbo that came wth the ca motorset i sold you was it?
ceniack
yeah, it was, but i didn't notice it, not a huge deal not mad at you or anything as you probably never noticed it either.
float_6969
PB Blaster. Advance Auto. Spray it on and let it sit. Repeat about 3 times. Also tap on it after you spray it on. Then use your easy out. If that doesn't get it, then you'll have to take it down and have it fixed.
ceniack
yeah, i have done the PB blaster, tap on it, repeat but can't get it, any idea how much a machine shop would charge for it?
Bwana
Car: Denali
Mine's exactly the same... Even with a drill press, plenty of penetrating oil, time and effort it was no go. So I'm running it with one bolt missing, no problems so far
rico05
Car: 1992 RMS13 w/ CA18DET
One bolt? Cost me $30 for 4 to be drilled out and heli-colied on my 13B.
nocwage
Have you tried cola?Soak it in cola for a while then spray it like mad with a penatrating oil..Cola seems to break down rust.. I dunno how but I've seen it used to remove rust stains and loosen rusted bolts many times.
float_6969
Coke is a moderate acid. That's why it's bad for your teeth, it eats the enamel off....
