SHE STARTS WOO HOO. BUT WONT KEEP AN IDLE!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Ok here's where i'm at soo far!
Ignition worksFuel injectors/ pump/ gauge look good 40psi in railturbo spools nicely aac valve you can hear air rushing through it
now just to get it to idle is the challenge now!
themadscientist
do yuo have to give it a liitle gas to get it to fire? try pulling the AFM. if there is no difference that could be the culprit. Is your ACC valve sucking air from the outside or from the pipetract? If you are using the OEM Skyline BOV it cannot be vented to the outside, it must be fed back into the hose between th e AFM and turbo, the spring is weak and it bleeds badly.
USMCgetsome
1.) yes gas pedal has to be half way down to start
2.)acc valve sucking air from throttle body3.)using turbo xs bov atomospheric
I'll try the afm deal and give a status in an hour(2043 time on deck) or so.
Thanks for the help!
SeVa-S13
Car: '05 GTO 6spd
Do you have an AFC of some sort to compensate for the atmospheric BOV? If not, that would be a big reason why you can't idle.
themadscientist
try plugging the BOV
USMCgetsome
ok now where at starting but very hard. very sluggish, have to give it at least 1/4 % of throttle. have an afc 2 but not installed yet. was worried if i installed it i'd have more problems. I can do the wiring but to configure the safc2 i don't know the in out values and all that bs. Do you guy think that can help or hurt my situation?
themadscientist
put that thing back in the box! Your car doesn't run correctly now, don't insert another variable. What did you do to improve the startability?
USMCgetsome
Installed
Nismo FprWalbro 255lphCleaned and ensured grounds read 0.0ohm to ecu and relays.recharged battery- to 100%
Then it started but i had to adjust the timing a little. Also, found a big vaccum leak. Top of the throttle body above acc valve. I have no other hoses loose. I can floor it and it picks up very slowly but i think it gets to about 5000 rpm and then stays there no higher. Fuel pressure stays at 40psi the whole time.
themadscientist
did you take a look at the turbo before you put the motor in? My boy's car did that and his exhuast wheel had exploded. are the plugs new? what do they look like?
JonPowell
Car: Cars, Music, My family
Did you ensure a good start signal to the ECU fromt he key cylinder?
USMCgetsome
i sent that wire to the ign relay #5 position. SO i know it gets it's 12vdc for starting. but i'll try putting it back to the orange wire.
USMCgetsome
well went to NISMO_425 house today to admire his swap that he did by himself. Mine is starting but running very badly.
