She's taking on water
rwbw00
Car: 1995 s14
My 95 S14 has developed a pretty significant water leak. It has been raining off and on for the last three days here and my care sat in the drive way all weekend. Yesterday I got into it and noticed a puddle of water in both of the passenger's side floor boards (i.e., front and back). The fact that both front and back were wet is alarming, because anyone who has had the interior out of a s14 knows there is a large ridge of sheet metal under the seats that would act like a dam. So, I am worried that I may actually have two leaks. I have checked all of the seals and have not noticed any torn places where it may be leaking. So, does anyone have any advice on how to track down an interior leak or where the water may be coming from.
drftsil8ty
Car: Cobalt SS turbo
take a hose and run it across the top of your car and you should be able to find the leak
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Does your S14 have a sunroof? Stupid Question I know but it had to be asked!
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
I was gonna ask the sunroof question too. My S13's drains were clogged so after hard rains the ring around the sunroof would be soaked. Drain O isn't just for household use .
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
all i know is get that water out of the floor as soon as possible!... it doesnt take long for mold to grow...
ddgsxr504
If it isn't the sunroof or you don't even have one then I would take a look at the door seals.
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
sit in your car and have a friend spray your car with water, your should find it instantly.
rwbw00
Car: 1995 s14
The door seals seem okay. Interestingly the problem occurs sporadically. When it rains sometimes it doesn't leak. For instance, last night it came a down pour but no leak. Also it doesn't leak sometimes when I go through one of those brushless washes. Thus, I think that the window does not form a tight seal sometimes.
Red coupe
Car: 92 Nissan 240sx Coupe
perhaps the seals seal better or worse with temperature change...or swell as they get wet so they leak at first then stop??? just thoughs...
Dattebayo
Every once in a while I end up with water in the S13's trunk and I cant explain it. It never happens two times in a row either. I had to pull the plugs in the spare tire well to get rid of it too.
I could not trace it, so good luck.
fatboy
Car: s13
2BN_S13 wrote:Every once in a while I end up with water in the S13's trunk and I cant explain it. It never happens two times in a row either. I had to pull the plugs in the spare tire well to get rid of it too.
i had teh same problem. my spare tire compartment was rusted through in a place. welded a plate over it, good as new
WeldingHank
Car: 1989 240sx CA18DET
your taillights are leaking.
Dattebayo
What are my taillights leaking then?
Blinker fulid?!??
fatboy
Car: s13
WeldingHank wrote:your taillights are leaking.
no they're not
JimmyMethod
Car: 97' 240SX SE
2BN_S13 wrote:Blinker fulid?!??
He heh he heh...
XingYu
Car: 1993 Nissan 240SX
did u check your tailight seals/gaskets whatever. pull out the plastic panels in the back and climb in. Have a friend pour water and see where its coming in from. Mine had water in the trunk and it was coming from that. Just take some sealant or something or go to NAPA and get some 3m butyl rubber and reseal it up.
