Zinister »
https://forums.nicoclub.com/zinister-u50298.html
Fri Nov 24, 2006 10:14 pm
Just thought I would share that I got my water pump in finally at the beginning of this week. Quick intro; My water pump was making nasty noises and the shaft on the pump that the pully was attached to was wobbling all over causing a coolant leak from the pump. I pulled the car into the garage and began slowely tearing it down while I waited for parts. I finally got it torn completely apart and still waited another 2 days before the pump came in, then I slowely began to put it back together. This was the first time I have ever had to do a water pump on a Z32. I must say it was alot easier than I was thinking, but it was still a pain in the ***. Well, the car started up just fine with no noise and no leaks! Just thought i would share!
